Evan Dutch
Hey. I'm preparing to replace the rear floor pans in my 72 dart. I've taken the area under the pans down to bare metal as best I could. But there is some pitted rust that I cannot remove with my tools. The shermin Williams close by sells ospho. My concern: after the ospho has done its thing I plan to spray over it with weld thru primer. Then weld the panel in. Is it safe to weld over the ospho prepared metal? The sds on the product says it's not flammable but will it smoke? Has anyone used this stuff? What else can I use to solve this problem?
