over centering spring
AG340Dart
Sooke B.C. Canada
Hey Boys, Just finishing off my auto to 4 speed conversion I have read in some posts that you are supposed to remove the over center spring in the pedal assembley is this correct?
Thanks and Merry Christmas
True, if you are using a diaphram style clutch. You don't have to remove it but it's not really needed with the diaphram style, much easier pedal without.
No problem, were all here to learn. There are 2 types of pressure plates , the Borg Beck type, which has 3 fingers in the center, and the Diaphram type which has a whole bunch of fingers in the center. If you go to Mancini racing and look at clutches they will specify the 2 different styles. Here are pic's of the 2 styles
[/ATTACH]
