Get rid of the junky 440 Source housing and pump !!
Ever heard of block fill. It the crap people pour in the block that they use to go racing with. Goes down the track and then shut it off Ive seen it done a lot (not my thing, I like to drive to and from the track). That or it didnt get tanked and cleaned before being rebuilt
The blok filler (correct spelling) is used to strengthen the block of race car engines. not meant for street engines. I run a 360 small block stroked to 408 ci. It makes 611hp and 545 ft lbs of torque. It revs to over 7000rpm. Thats why guys use blok filler in a engine.What advantage does filling your block with this crap give you?
Let us see. A 440 we just got back from Dvorack Machine won't go above 160. At 32 degrees, because that long stroke needs less timing. Search Dvorack, and see how many titles he holds. I have spent a lot of time with him, and have learned more than you can on line.33 degrees total is not enough advance for a healthy 440. I have been fighting the same problem and my machinist suggested more advance. I was running 220 and above with 36 degrees advance total and would shut it down at 230 cause I didnt want to hurt the motor before I figured it out. With 40 degrees total it runs at 200. This is a 500 with aluminum heads flagella and a stout solid roller cam at 10 to 1 that runs on 93 octane. Give it a shot. What ya got to loose?
