what thermostat temp is it running? is the coolant level correct? is the belt on it? is the radiator clear inside? is the pump leaking out of the weep hole? what was the outdoor temperature? were you flogging it? was the transmission overheating? did i welcome you to the site? doyou wear clothing? is your mom a girl? are you a human? wait, scratch the last 2 questions. welcome to fabo.
