Can someone tell me if installing the engine builder valves is going to require having all new valve seats installed or is it just a matter of cutting what is there.
Also how will installing these valves affect my CC measurements. The head is 60 cc now but will installing these valves make that number get lower or higher?
Will there be any valve shrouding using these valves. I have read that the chambers will need to be swept/valves de-shrouded after their installation, any truth in that?
Im going to guess that installing the larger valves and then sweeping/unshrouding the valves ( if that were needed to be done ) would cancel out one another if bigger valves were to reduce chamber size at all but that is just an un-educated guess.
Thanks
Thanks
