[FOR SALE] PA: 318 engine, marsh aluminum pulley, vintage air
m880cummins
Parkesburg, PA
Rating - 0%
0   0   0
For sale is a 318 out of a 1985 dodge air force truck. Has approx 90k miles and was run on propane its whole life. Recently, it received an edelbrock carb, intake and MP valve covers. New distributer was installed along with new wires and has a mallory CD ignition box and MSD coil. Has a new aftermarket harmonic balancer. Runs great! Super clean inside because it ran on propane. Oil pan leaks a little bit so included is a box of new parts such as a reusable pan gasket, main seals, Melling oil pump, pickup tube and pump shaft, valve cover and timing cover gaskets, edelbrock carb jet kit, and spare thermostat. $600 firm. You can drive it before I remove it!
Also have a NEW March SB crank pulley. Billet aluminum with double serpentine.
For sale is a complete vintage air kit #506101 MSRP $222.58 and the #31400-vud heater hose kit with fittings MSRP $50.24. Both are complete and were purchased March of 2013.
$200 shipped in the 48!
