Snake
Mopar Nut
If I was to paint my 74 Duster head liner ,can it be done and what type paint to use.I just pulled it out and plan on using it too save money.
The cardboard, fiber board one I assume?
I painted mine with interior dye that I got at O'Rielly's.
Hey Don,
I recently did mine with flat black Rustoleum and a 4 inch foam roller and it turned out real nice.
At first I did it with satin but it was just way to shiny, so I went back over it with two coats off flat.
Home depot had a 4" foam roller and a little tiny paint tray kit for less than 5 bucks.
Sweet I was just a home depot takeing a look see,if it work for you well ,i wonder if they have flat white?
I had thought about covering mine, but decided against it because if the outer layer of the fiber board starts coming loose then you would end up with a sagging fabric headliner.
Sure they do.
Even better,did you have to wash befor painting? the liner that is lol.
i guess anythings possible, mines been on the car since 72 and still looks great. washing them or getting them wet might cause it to delaminate. mine, being black, doesn't need much attention, so i rarely clean it. dave.
For what it's worth mine has lasted over a decade.
If you are going to spray it, use a paint gun.
I must be the unlucky one, I did one a few years ago, and driving with the windows open allowed air to get up in there and it started separating.
I'm thinking the fiber started separating from moisture or something. Once that happened there wasn't any saving it.
Well I painted it looksssssssssssssssss great,thanks for all the help you all ROCK.
