The fact it is a single stage and metallic has no bearing if he is going to repaint the car.
Sure it does, especially if he plans on re-shooting a single stage metallic! :-D
I only say to cut the runs down because they're easier (and faster!) to cut down when they're soft vs. waiting for that big glob of paint to dry and then spend an hour sanding it out. Either way the whole thing will have to be sanded.
I've sanded plenty of single stage paints, as long as there's enough paint (ie, you don't sand it so thin you can see the primer) it will not change the hue. Hence "color sanding" with 1200+ grits. However, sanding a metallic is pretty useless since whatever was there before will probably still be visible as a "shadow" when you're done because of the metal flake concentrations.
Buffing a metallic will not turn it silver unless you buff all the paint into oblivion. At that point you'd have ruined whatever kind/color of paint you were buffing anyway, base/clears included. That's not a metallic paint problem, that's a buffing problem.
Single stage paints, IMHO, are about a million times easier to deal with than a base/clear. You can always color-sand, polish, buff or even spot paint a single stage (ok, not so much if its a metallic, there's always an exception). Not so with a base/clear. Once that clear goes on, you're pretty much stuck with what you've got. And no worries of that clear coat checking, peeling, or turning white, or yellow, as I've seen numerous clear coats do. Hell, the clear on my Challenger is peeling off as we speak (no, I didn't paint it, I have the PO and probably maaco to thank for that :angry5
. True, single stage paints require a little more work to keep up, but if you know how to do the work I think the result is much better.
