Paint Shortage
Some colors are very transparent. A lot of paint systems call for a specific color sealer or even a solid color ground coat.
Omni, you do realize the second tier products don't have the same bank of toners available as the first tier line. I don't use omni because there have been several instances where I couldn't get the color mixed I needed for lack of not having the right toners/pearls in the mixing system. Nason, the same way. There's not the same toners available to get there. Second tier products generally have less pigment per volume. When it comes to partial paints and blend-able matches sometimes you need the good basecoat.
I sure do now with regard to pigment volume. you are correct.
