240 gordy
Am converting the front drums on my 69 Dart 340 to discs and was trying to decide what color to paint the items that need to be painted. Was thinking gun metal grey but am open to suggestions. Don't want them to rust..
Fantastic --Thanks so much--where do you guys find all this stuff ?This may be helpful to you. I've had it for years and successfully relied on it time and again. (I apologize in advance if the formatting gets weird -- it doesn't copy and paste well on forums so call me if you have questions about something.)
Mopar Chassis Color Chart
Legend:
BC: Body Color
GB: Gloss Black
SB: Semi-gloss Black
CI: Cast Iron Gray
N: Natural Steel or Aluminum
MP: Manganese Phosphate
CC: Color Code
(*): Some Mopar core supports are body color with semi-gloss black sprayed on the grill side. There are some variables from what is shown above.
Assembly: Front Unibody subframe assembly BC
Inner Fenders BC
Firewall BC
Core Support BC*
Transmission Components: Transmission N/CC
Driveshaft N/CC
Transmission and driveshaft Yoke N/CC
Differential Housing SB
Clutch Linkage N
Brake Components: Brake Drums SB/N
Disk Brake Shields N
Calipers CI
Master Cylinder GB or CI
Axle/Suspension Components Axles N/CC
Third Member SB
Upper Control Arm GB
Lower control Arm GB
Inner and Outer Tie Rods N/CC
Tie Rod Adjustment Sleeve SB
Center Link MP/CC
Idler Arm/Bracket CI/CC
Suspension Components(con’t) Strut Rods CI/CC
Torsion Bars GB/CI/CC
Shocks SB/CC
Rear End U-Bolts N/CC
Rear Leaf Springs N/SB/CC
Backing Plates GB
Spindles CI/CC
Anti-Sway Bars N/CC
Steering Components Pitman Arm CI/CC
Steering Box N/CC
Exhaust Systems Muffler Hangers and Clamps N
Exhaust System and Mufflers N
Gas Tank Components Gas Tank N
Gas Tank Straps N/GB
Gas and Brake Lines N
