paint
dartman1965
bay city michigan
What paint do you guys recomend for things like trans mounts and k frames and things?Im doing some work on my underneth and want the paint I use to last.I know por 15 is good but im on a strict budget so its parts store stuff I need.I did my trans pan with vht hot paint and it came out great.The rest of what needs to be done is to big.thanks
I strongly recommend you beadblast the parts first. Then, use an epoxy primer and follow-up with a single-stage, urethane topcoat in a black satin finish.
