[SOLD] Pair of 5.7 hemis and parts
DOHCeclipse
iowa
I have a pair of 04 5.7 hemis I'm looking to sell. The first is out of an 04 durango and is very complete minus ac compressor and serpentine belt. Has a 545rfe trans bolted to it and the wiring harness is still on the motor. I have the ecu, drive by wire gas pedal, and even the factory air box from the durango also.
The second hemi is from am 04 ram 2500 and I was told it had a knock in the bottom end which is why it was removed from the truck.
I also have another 04 engine wiring harness and fuel rails with injectors.
My plan was to swap a 2wd tail housing onto the 545rfe ($200) and drop the first hemi into my duster while building a stroker out of the second one. Plans have changed and now I would like to move this stuff out of my way. Would like to get around $1700 for everything.
If your willing you part that broken engine out. I could use a set of lifters with the retainers. Its just a core at this point. Only thing in the hotrod world anybody would want is the block, front cover, and the non mds lifters. Hence my interest in the lifters. Also the rockers are useable on other years. Well the ecms and trans are possible as well if you have complete vins. Harness as well with them with the trans i suppose.
