[WANTED] parts for 273 Motor for 66 barracuda
hemihead123
elmira ny
Rating - 0%
0   0   0
I need parts for the 273 motor that I am rebuilding .
Parts needed:
cam and lifter kit
complete gasket set
cam bearing kit
soft plug kit
timing chain and gear kit
vintage correct air cleaner
cater AFB 4 barrel carb
A/C brackets
you need to just buy all your "kit" parts and gaskets from you local parts place. older gaskets may be cheap, but they are brittle and will not seal properly. pick out a cam you want and buy it from jegs or summit. on here is a good idea for the air cleaner .
:burnout:
