Parts for sale or trade!
zac_F71
Clitherall MN 56524
Well after Xmas/New Years I'm starting my Demon project back up and changing well everything- got some parts I won't be using... will have pics of everything sooner or later all prices are shipped to the 48 states - all others PLEASE PM for a quote
ACC 727 stall converter used very little - came out of my running/driving 70 340 Dart asking $250 shipped- see link
http://www.summitracing.com/parts/ape-54093
1 set of 14x5.5"" LBP Rallye wheels w/ 4 72 style Acorn center caps, 2 have 225/70/14 Dayton tires w/ 50% tread asking $300 WITH OUT shipping (no trim rings)
1 pair 15x6 Mopar steel wheels w/ 225/75/15 tires $150 shipped - $100 shipped w/o the tires
1 set of 4 brand new Monroe "blue" shocks brand new- mounted but not driven on asking $60 shipped
1 pair of 6cyl leaf springs on my 71 Demon 89k on them- asking $150 shipped
1 pair of new leaf shackles $40 shipped
1 pair 2.5" axle "U" bolts brand new $40 shipped
1 pair 2.5" shock plates from my 71 Demon $50 shipped
1 pair front spring hangers off my 71 Demon $50 shipped
10" front disc brake setup from Scarebird LLC- all brand new- custom one off hubs for LBP includes the 1971 9" drum spindles off my Demon, new rotors, pads, calipers, soft lines, bearings/seals, lower ball joints, and caliper brakets- all parts but needs 2 dust covers ($4ea from Oreillys) $800 shipped can be drilled for SBP as well
stock original A body upper control arms- w/ new ball joints 0 miles on them - 1 joint had to be welding in as it wouldn't tighten up in the arm asking $100 shipped
stock 89k 225 slant 6 has a BUNCH of new parts $250 w/ the 904 Auto trans $300 w/ the electronic ignition wiring/parts- NO SHIPPING- new parts- water pump, timing chain, cap and rotor, custom Taylor plug wires, plugs, oil change, new intake gasket set, new chrome valve cover, NOS fuel pump, new hoses, Lokar kick down cable, and new V belt.. trans has new filter/fluid but needs a new gasket as it started leaking- I'm keeping the alternator/starter. (motor includes a 1bbl intake/exhaust mani, and Holley 1920 carb that needs a kit as well as a air cleaner base) NO LONGER HAVE THE 4BBL SETUP SO DO NOT ASK -PM's for it will go un-answered
stock slant 6 drive shaft with new U joints (A904- 7.25" rear axle)$65 shipped
LOTS of base model body wiring PM or post with needs
recovered black 73 Duster front bench w/ original rear bench seats Asking $350 no shipping
V8 w/ A/C brass radiator w/ auto trans cooler in great shape $75 shipped
6 SBP 14" steel wheels w/ tires, tires are worn and dry rotted but good for rolling a chassis around.. $100 for all 6 no shipping OR $300 shipped for just the 6 wheels..
Rubber motor and trans mounts for slant in A body $40 shipped
Black Volare steering wheel missing horn button $30 shipped
73 A body 7.25" LBP rear axle, been rebuilt at one point w/ Timken bearings the fluid looks new so I left it and resealed the cover, has ALL brand new 10x2.5" drum brakes on it includes new pre bent hard lines (no "T" or soft line)- will make a package deal on it and the other 7.25 parts I have above asking $300 no shipping for just the axle/brakes, $400 for all the 7.25 stuff again NO shipping but it will be bolt in, bleed, and go...
(no longer have the 4bbl setup)
Still have dash cluster
That is not for sale sorry you can make yours like that though!
the gauge overlays are from www.whitegauges.net
the colors are -
aluminum (non-metallic)
gloss black
Minwax polyurethane clear coat
Paint the whole thing (after taking the cluster apart) aluminum first then tape off parts you want to stay aluminum and spray black, then remove tape and apply clear... probably want to let each coat dry for 24 hours..
(make sure to peel off the fake wood trim also)
