demon428
I put together a parts list for my stroker motor
everything in black I have already in Red need to purchase or find the best part for my application.
If I am missing anything or you have a suggestion I am all ears
360 motor mount brackets
MOLNAR-360 4.125 Chrysler 4340 Forged Crankshaft 360-4125FA6F
MOLNAR-Chrysler Small Block Rods
stroker pistons, 4.030"
Race Piston Rings
Clevite 77 rod bearings
Clevite 77 main bearings
Federal-Mogul cam bearings
Dual crankshaft scraper
complete engine gasket set
front cover gasket set
pushrod set
Milodon windage tray
Milodon Crushproof Premium Pan Gaskets
Fuel Pump and Regulator Kits
Electric Fuel Pump Relay Kits
Crankshaft key
Front main seal
Rear main seal
Milodon Main Cap Kits
MAIN STUD GIRDLE KIT 360 ONLY
Remote Oil Filter Kits
Remote Oil Filter Mounts
ROL Manufacturing hi-temp cylinder head gaskets
Aluminum Radiator
Dual Radiator Fan and Shroud Kits
Thermostat, 180 degree operation
Mallory Pro Sidewinder Spark Plug Wire Sets 937
ARP accessory bolt kit
ARP thread lubricant
ARP thread sealer
engine enamel
mini-starter
TG-8955 - Stage 8 Locking Header Bolt Kits
Mopar 360 cast iron engine block, 1976 casting
Milodon Freeze Plug Kits Milodon 34040
Bronze distributor bushing Oil Pump Driveshaft Bushings DCC-1737725
Lunati Voodoo Hydraulic Flat Tappet Camshaft and Lifter Kit 638-10200705LK
Milodon Gear Drive 13600
Melling hardened oil pump driveshaft and distributor gear MEL-IS-72
Melling high volume oil pump MEL-M72HV
Milodon Oil Pump Pickups Milodon 18343
Milodon Road Race Oil Pans 31595 MIL-31595
Milodon Stainless Steel Oil Dipsticks Milodon 22061
Mopar front timing cover, used N/A
CSI-903C - CSR Billet Aluminum Electric Water Pumps CSI- 903C
MRL Heads full ported with dual springs 2.08/1.60 valves PROCOMP
Harland Sharp Heavy-Duty Roller Rockers 1.6 Shaft Mount Rockers S70026K
CVR Thermostat Housings CVS-TSH8R
Edelbrock RPM Air-Gap Intake Manifold Edelbrock 75764
750 CFM , Mighty Demon carburetor with manual choke DEM-5402020GC
Air Cleaner Assembly, Elite, Oval, 4-Barrel, Aluminum, EnduraShine, Edelbrock EDL-42364
Fabricated Aluminum Valve Covers N/A
Aluminum Valve Cover Oil Filler Cap - 4120453 PRW4120453
Edelbrock Elite Series Breathers 4201 EDL-4201
Mallory Comp S/S 42 Series Distributors 4257911
Mopar Performance front cover bolt kit Chrome Timing Cover Bolts DCC-4529256
flywheel, 130 tooth, 11 inch, SFI approved, internally balanced
Mopar bell housing for A833 manual transmission, 10.5-11" N/A
Dougs headers D453
Centerforce Dual Friction Clutch CTF-DF269739
CVR Fuel Pump Block-Off Plates CVR BOP64R
Proform Engine Lift Plates 67457 PRO-67457
Doug's Headers 3" Electric Exhaust Cut-Out DEC300AK
Race Piston Rings
pushrod set
Crankshaft key
Front main seal
Rear main seal
Aluminum Radiator
ARP thread sealer
engine enamel
mini-starter
Dougs headers D453
