parts NEEDED ASAP
i've got a set of magnum rockers do you have the magnum heads?? if i were you i'd just run throttle body heads (premag heads) and you'll still have swirlport and they bolt right on to a LA motor.
But you won't get the closed chamber and improved exhaust port.
The conversion push rods are $40 from Mancini, I wouldn't bother messing with used at that price.
You can harvest the rocker gear from any magnum engine at your local pick-n-pull junk yard.
True i forgot about the exhaust ports and such.....thanks for clearing that up :D
still need these parts real bad. please help also looking for a 70 dart gril the really nice ones
but will pay asap for pan and sump
