Suregrip391
Oh Boy, Ill try my best to explain what I need. I'm not sure "exactly" what they are called so bear with me...LOL (these are for my 67 barracuda but may fit other applications?)
I have my dash apart and I found out that I need a replacement heater/AC switch (the one that the vacuum lines hook to) Mine has a couple broken off vacuum ports on the backside.
I also need the proper clip that holds my heater control cable down to that same switch plate. Mine is missing. (see pic)
I also need to get a hold of one of those lock washers that presses onto the "pin" (The pin is what you put the coiled up end of the heater control cable over, then the pressed on lock washer prevents it from popping off.
So this is what I need the (1) proper lock washer, (2) a heater control cable hold down clip, and (3) a new/used ac/heater switch for a 67 barracuda if you can help me?
I would like to get this all back together by next week if possible. Pics attached so you know what I am up against here. Hope that all makes sense? By the way, if I don't plan on using the A/C, will I still need a new switch will all the vacuum ports? I just plan to use the heat from time to time, no A/C. Can I get away using my old switch then? Thanks all.
