[WANTED] Patch panels
zigs
Yakima, Washington
Looking for rear lower patch panels for a Duster. I think all years are the same in that area. From rear wheel well back
about a1 1/2 'as shown in the picture.
Need both sides
AMD $139 a piece . I was hoping to get around it. What is your picture ?
blurry on my end . Are you selling new?
If only doing below the body line its easy enough to just use flat sheet metal. Will blend right in with a light coat of filler. Don't have a brake... I made edge bends by clamping between wood and tapping across with hammer till I had them bent as needed.
