1. 440dartsport
    440dartsport Well-Known Member
    607
    131
    Oct 14, 2010
    Kewaskum, WI
    Local Time:
    10:07 PM
    I am in the process of putting a 440 in my 74 Dart Sport. I am going to be converting it from Power brakes to manual. What is all needed to do this conversion. Master cyl adapter and rod? Also what is a good master cylinder to use that still gives you good braking?
  2. 71DartGuy
    71DartGuy Well-Known Member
    1,895
    4
    Jul 24, 2007
    Muncy, PA
    Local Time:
    11:07 PM
    I didnt think the masters were different from power to manual, just from disk to drum. You will need a different pushrod though.
  3. dgc333
    dgc333 Well-Known Member
    4,125
    24
    Jan 12, 2005
    Pembroke, MA
    Local Time:
    11:07 PM
    The bore of the MC is different between manual and power so you will need a manual MC. You will need the rod but the MC bolts directly to the firewall so no adapter needed unless you plan to use a late model MC with the plastic resevior.
  4. 440dartsport
    607
    131
    Oct 14, 2010
    Kewaskum, WI
    Local Time:
    10:07 PM
    Thanks guys. Is there a master that works better than others? Something that anyone would recomend?
  5. 71DartGuy
    1,895
    4
    Jul 24, 2007
    Muncy, PA
    Local Time:
    11:07 PM
    I got a reman unit from my local autozone and it works just fine.
