PCV hose question?
Mr.FT
New Jersey
What is the I/D of the hose that runs from the air cleaner to the PCV valve on a 72 340. I would measure it but I'm at work and wanted to stop on the way home pick it up.
Thanks
PS: it's the stock trap door air cleaner.
Air cleaner to breather is usually 5/8 never seen one to the PCV....
mguner, you are correct, now that I think about it . It does go to the breather cap.
Thanks
Tom
MrFT , where does the vacume line on the trap door air cleaner hook up? PO had it all un hooked. Have asked this question a couple times and have not received a response.
Yote
You run the line for the front danper to the first fitting on the bottom of the air cleaner. Then I ran a small piece of hose to the other fitting on the bottom and put a tee in that line one side went to trap door and the other I spliced into the vac advance with another tee. If you PM me your email address I'll scan a pic and send it to you.
Hope this helps
Tom
