carcrazyguy
Starting to look things over after getting the Duster back. I did not have brake lights so I started to track that down. Figured out it was the brake light switch not adjusted. While tracking that down I noticed the brake pedal had a lot of play. Lowered the steering column to attend to the pedal issue. It appears the bolt through the pedal and rod is a shoulder bolt and may be as tight as it will go? But the pedal still will move and allow the bolt to move without pulling the rod that goes to the booster? Is there suppose to be a bushing around the bolt where it fits the push/pull rod to the booster?
