pedal wiring
Shadow9198
Active Member
berta
ok so im at a stand still here. im trying to locate the plug that hooks into the throttle pedal right now for the drive by wire and i cant find it. ive been all through the cab wireing harness from an 05 1500 and cannot find the plug anywheres. is it in some other harness or something? i only have the big main harness that hooked to the engine bay and i didnt take every wire from the truck cab since i didnt need all the heads up display and cab lights wire so i unplugged it and left it. is the drive by wire plug in with those?
Not sure about the under dash harnesses, mine was separate from the harness I got on ebay, I snipped my pedal pigtail from an 04 Durango in a pull and pay junk yard and spliced them into the harness.
