PH 318 Water Pump
Robert Dart
Burley, ID
Hello, thanks in advance for your help.
I have a 360, block year 1978 motor previously purchased. It has a "PH 318" water pump. I can't find any specs/details of pump. Can anyone help? I am trying to determine if this water pump is standard flow, etc.
Thanks again,
Robert
Just run it. If you really want to know if it's a modified 6 or 8 vane, pull it and look. The impeller will have a flat disc attached to the back of the impeller if modified.
That's an aftermarket pump. Have no idea what brand.
