Photo needed
jim
Trying to rundown a oil leak on the back of a /6. Changed rear main seal and still have a leaker. Does some one have a photo of the block so I can see where the oil port plug is located and also cam cap. Motor is in the car and don't want to pull at the present time. Motor was to be rebuild awhile back. Not sure if that's the problem.
Thanks
Jim
So are you looking for a shot of the back of a slant 6 block without the trans on so you can see the plugs etc???
Maybe a better pic.
Here's a shot of my kaput 65 block, from the rear.
Large round circle to the right is the steel plug covering the cam, while the smaller round circle next to it is the pipe plug for the main oil passage. There is an oil passage at the rear of the block, going up from the block and into the head for rocker shaft oiling.
FYI, the rear main seal cap is not on the block in the picture.
That's what I need. Thanks guys
