Pics of 4 link systems
Suspension, Steering and Chassis
  1. fishy68
    fishy68 Tyr Fryr's Inc. FABO Gold Member
    16,949
    930
    Jan 11, 2005
    Central, IL (Hooterville)
    Local Time:
    10:02 AM
    Anyone here done a 4 link on their A-body? If so I'd sure like to see some pics. Especially of cars with full exhaust systems cause I'd like to retain tailpipes. Thinking about doing it on my Cuda over the winter. Haven't decided which would be better/easier to do, parallel 4 link with panhard bar or triangulated 4 link
    Thanks, Tracy
  2. Cope
    Cope Fusing with fire
    4,077
    4779
    Oct 20, 2009
    San Jose, Ca.
    Local Time:
    10:02 AM
    If you're gonna four link, thank about what you want it to do and why.
    Parallel is not great unless it the front end of a 4x4. (Even then it's not great)
    You need to think about the total arc you want vs. The deflection of your joints.
    Drag race, auto cross?
    • Thanks! Thanks! x 1
    • fishy68
      16,949
      930
      Jan 11, 2005
      Local Time:
      10:02 AM
      Mostly street driving but it needs to hook up good. I have a full CalTrac system (springs, bars and adjustable shocks) on it now and can't say it really hooks much better than the stock leaf springs. I have 275/60/15 Mickey drag SS radials on it. The main thing(s) I don't like about the Caltrac setup is the harsh ride and the right spring squeaks. I can probably take the spring apart and grease it to stop the squeaking but that won't do anything for the ride
      • fishy68
        16,949
        930
        Jan 11, 2005
        Local Time:
        10:02 AM
        Curious, why don't you like parallel? I've rebuilt numerous stock suspensions over the last 35 yrs. but new to the performance aspect of them
      • Cope
        4,077
        4779
        Oct 20, 2009
        San Jose, Ca.
        Local Time:
        10:02 AM
        Parallel is just a ladder bar with an adjustable instant center.
        Do you need to adjust you instant center?
        • Cope
          4,077
          4779
          Oct 20, 2009
          San Jose, Ca.
          Local Time:
          10:02 AM
          Both do the same thing.
          They center the axle.
          The difference is the amount of twist in the joint. Where do you want twist.
          Call track it some what of a gimmick in my opinion.
          All these systems come down to instant center.
          If your pushing high your front end lifts, push low and blow the tires off..
          • fishy68
            16,949
            930
            Jan 11, 2005
            Local Time:
            10:02 AM
            Not sure. Just toying with the idea. As I mentioned above I'm green when it comes to high perf rear suspensions and i'm looking for something that'll hook better and ride better. It also looks like it may give me a little more tire clearance that the leaf springs so I can get the next wider tire under it. I just found a book on Amazon I'm thinking about ordering. Seems Chris Alston has quite a bit of input on the subject so I think I can trust it
            Thanks for your replies
          • Cope
            4,077
            4779
            Oct 20, 2009
            San Jose, Ca.
            Local Time:
            10:02 AM
            If your gonna remove the frame rails and back half the car, go triangle.
            • fishy68
              16,949
              930
              Jan 11, 2005
              Local Time:
              10:02 AM
              Wasn't planning on going that far. I've seen pics online of a couple systems that install without ripping out the whole back end. Can't afford one of those high dollar setups but I have the tools and ability to build my own. Just looking for input, and hopefully some pics of guys here that did their own
            • Cope
              4,077
              4779
              Oct 20, 2009
              San Jose, Ca.
              Local Time:
              10:02 AM
              I'm building both, first I'm building a parallel for our shop truck, because that's easier for the steering to work around.
              Second I'm gonna build a trianglelated for our drag car.
              Both require a lot of thought but remember they both do the exact same thing.
              The difference is the panhard bar. That bar is all that hold your axle side to side.
              It has limits as to how far it can rotate do to its mount.
              No telling what failed first in our last set up but something let go. I'd bet the Panhard locked up causing the parallel links to bind. Then all hell broke loose, pinion sheared off, the axle twisted, the the four link bent and the drive shaft wanted to be in the car.
              • mopardude318
                mopardude318 Well-Known Member
                9,658
                812
                Jan 7, 2005
                Gilroy, Ca
                Local Time:
                8:02 AM
                I have the RMS street Linx kit installed into my car.. it's a triangulated setup. I had intentions of driving on the street.
                • Thanks! Thanks! x 2
                • AAndrews
                  AAndrews Supercuda
                  526
                  437
                  Nov 5, 2014
                  St. John's, Newfoundland, Canada
                  Local Time:
                  12:32 PM
                  Here's a pic of my Streetlynx setup. A breeze to install, adjustable coilovers and a rear sway. Check the second pic for how well this setup tucks up into the car even with rear exiting exhaust.
                  • Like Like x 2
                  • Mtrhead
                    Mtrhead Ace of Spades ♠️
                    1,891
                    540
                    Sep 19, 2018
                    S.C.
                    Local Time:
                    11:02 AM
                    Nice setup..looks simple enough to fab up
                  • 70chall440
                    70chall440 Mopar or No Car...
                    285
                    267
                    Jun 9, 2018
                    Yelm WA
                    Local Time:
                    8:02 AM
                    If you are going to drive it hard like road race or Auto X, triangulated is the way to go. If you are drag racing, parallel works great (lots of adjustability). If you are just driving it on the street, leaf springs will get it done with a good sway bar and shocks.
                    • Agree Agree x 1
                    • Mtrhead
                      1,891
                      540
                      Sep 19, 2018
                      S.C.
                      Local Time:
                      11:02 AM
                      Ty you just answered all my questions and some.
                    • 70chall440
                      285
                      267
                      Jun 9, 2018
                      Yelm WA
                      Local Time:
                      8:02 AM
                      Welcome. Of course like anything there are a lot of varied opinions on this, but if you step back and look at it objectively and factor in what the car will be used for, or better said what you want out of the suspension, I stand by my statement. Of course the best is IRS but that is opening a whole other can of worms :)
                      • Agree Agree x 1
                      • fishy68
                        16,949
                        930
                        Jan 11, 2005
                        Local Time:
                        10:02 AM
                        I wondered about the limits with the panhard bar too. Thanks for the info. Sounds like triangulated is the way to go
                        Wow! Carnage is always ugly.
                      • fishy68
                        16,949
                        930
                        Jan 11, 2005
                        Local Time:
                        10:02 AM
