pilot bearing for 360 magnum /T56 swap
737jetdr
Martinsville, In.
I'm sourcing parts for a T56 trans install in my 67 Dart. I will be using a T56 from a 2001 Firebird which had the LS motor in it and a Quicktime bellhousing. Does anyone know where I can find a pilot bushing that will work in my 360 magnum motor for this T56? Thanks
Thanks for the info. Not sure if the viper input shaft and LS input shaft are the same o.d. I will look into it.
I am currently trying to find the right pilot bearing.
A Viper T56 input shaft is around 3/4" and a GM T56 input shaft is 5/8". The crankshaft is 1-13/16".
I had bought the pilot bearing a long time ago and turns out it's a LA to Viper T56 bearing.
Anyone out there have a part number or link to a LA to GM T56 bearing?
