dmopar74
Im swapping in a 8.8 rear end and need to set up the pinion angle, I've always heard equal but opposite so if the trans was 3 degrees down the the pinion would be 3 degrees up. Then I've read to add or subtract up to 5 degrees but think 2 degrees would be ok for a street car? So if trans was 3 down as an example then pinion would be 1 up?
