340_833 dart
I've been dealing with a minor driveline vibration ever since I swapped a 727 in place of the 833 four speed.
The U-joints are brand new, as is the transmission yoke, and I had the entire driveshaft balanced. That lessened the vibration but it is still there.
So, today I went to this web site; http://www.wolferacecraft.com/pinionangle.aspx for instructions.
The measurements on the pinion yoke and the driveshaft were identical.
Does that mean I need to get wedges to point the pinion down? Is the ideal down angle 4 degrees?
