pinion shims
75ddart
Pa.
Anyone here have a source for obtaining just shims for setting up pinion depth ? I would like to get locally, but haven't had any luck only through mail order and I'm no longer comfortable giving info over the net, Tried the various chain stores but no one stocks or can get a shim kit, only the complete ring and pinion install kits, which I don't need or want to spend the money on that kit for only what I need. Diff in question is a 741 case 8/34, thanks..
Got mine through the local Chrysler Dealership. P4529536 Axle Shim Package, Rear, 8-1/4"/ 8-3/4"/ Dana 60 Axles
P5153561 Axle Shim, Rear, 1°, 2pcs.
P5153562 Axle Shim, Rear, 2°, 2pcs.
P5153563 Axle Shim, Rear, 3°, 2pcs.
Sorry wrong info
Thanks for the reply, but need pinion shims not spring.:D
I have gotten shims for the inner bear at the local farm supply store. never checked but they may have the front shims also. They are in the pto drive shaft, bearing and u-joint area.
order from Summit Racing --- RAT - 1109 -- $13.00 -- I believe 8.2 10 bolt GM will work also.
