Piston pin offset "controversy"
My understanding is that reversing the factory piston offset gives a more favourable rod-to-crank-angle [ leverage ] & it is this that can add a small amount of HP.
Don't see a friction benefit because when the rod changes direction at TDC, the piston is stationary & movement/motion is reqd between two surfaces to create friction.
You guys are all getting played by a bunch of YouTube whores starting a fake ***** festival to get more views...and make money so they can build cars while you have to go to work...
It does reduce drag inside the engine, supposedly with an increase on noise, but it's barely noticeable, mostly when cold. I have done it for 35 years in re-ring type performance builds with stock pistons, and "replacement" forged TRW pistons which are also offset. The 1/16" ring TRW "performance/race" pistons are centered pin. On a 440, with 2355F 6-pack forged pistons, reversed at .0035" skirt clearance, there is barely any noise factor cold. A 360 with Badger cast pistons fitted at .0015" and reversed, no audible piston noise at idle cold that I can detect. I cannot verify back-to-back performance gains, however.
This is probably the best post in this thread ! LOL! Someone who gets what UTG and others like him is about. Why do you think he is building junk? because everyone else already had a show where they order all the best out of a Summit/Jegs catalog and put it together. UTG had to come up with something different to be marketable. That piston offset BS with Freiburger was probably set up via a phone call to gain views for both channels.
