[WANTED] pistons
moparraceman
mansfield ohio
need 1 - 340 4.030 which is .030 over flat top pistons for a 340 small block good used stock from 71 motor[probably several years the same ] with stock rod pictures and price ? shipped ti 44905 ohio thanks
High compression with single valve reliefs or low compression with double reliefs. They shipped both in 71 dated blocks I think.
The standard 340 bore size is 4.040". A .030" over piston would be 4.070".
The standard 360 bore size is 4.000". A .030" over piston would be 4.030"
Which do you need?
Maybe post a pic of what you are trying to match? I have some 340 pistons but I can't tell what you are asking for.
