dartfreak75
Restore it, Dont part it!
Yea that axle seal is a b!$#h! I got it yesterday.I have that same 01, 4x4.
When I did the hubs I just pulled the entire axle assembly out (hub still attached) and brought it into the corner shop and had them spin that nut off. Also a socket wedged between the u joint and the spindle, and then a turn of the power steering pops that hub right out. Sadly I've seen people beat that hub off when there is no need to.
Be careful of that passenger inner axle seal. I had the worst time replacing that after it failed.
Good luck!
