Do not use the thinner on the plastic, if it does melt it, it will turn it white/cloudy.
Try using rubbing alcohol or regular paint thinner (mineral spirite) on a small area. If those don't work, try the corner of a razor blade and carefully scrap it off.
After you are done, either use the 3M stuff or another polish.
I speak from a bad experience on this one.
