hemiorange
For my 1970 dart swinger - Is there supposed to be play in the door latch when the door is closed/engaged in the striker pin? I don't currently have the door gaskets installed and the door sits flush with the quarter panel when I pull the door as if opening it but if I push it closed it gets pushed past being flush by about .25-.5 of an inch, making it difficult to do body work on the quarter panel/door lines.
Do I need to install the door gasket to keep it flush while doing body work or is there an issue with the door latch?
