jasonmrenda
- Joined
- May 13, 2009
- Messages
- 271
- Reaction score
- 1
can anyone tell me if the actual power steering gear box is the same for a 67 dart GT 225 /6 as a 76 dart Swinger 318? the bolt holes line up and the steering col seems to fit (at least temporarily).
the pitman arms on the boxes are shaped differently. my 67 pow steer gear box is good but i cant use the 67 pitman arm. the 76 pow steering box is bad but i need to use that pitman arm. can i swap the 76 pitman arm TO the 67 gear box? are the splines the same? i got the 67 gear box installed but forgot to swap the pitman arms so i cant get the suspension done till i work this out.
