I know this isn't about my 65 Plymouth Valiant, but it's at least Mopar related. I'm finishing up my 73 Charger restoration and was attempting to test the lighting system last night. The battery I had only had 11.50 volts and 186 CCA. So I had it charged today and now it has a full 12.5 volts and 860 CCA. Well last night I was able to hook up everything without any sparks at the battery probably because the battery was so low. Most all the lights worked, the glove box, gear selector, dome light, and right rear tail lamps didn't come on but everything was conncected right. So when I went to connect the battery today to retest everything the large spark occured and melted my new positive cable and fried the starter relay. None of the instruments are on and I can't find any wire that's touching anything metal. There is a 14 gauge red wire that should connect to the B terminal of the relay, then into a fusible link, then turn into a 10 gauge red wire that goes to the Ammeter. If I follow that wire on the wiring diagram it says 60AMP. I now have a 60AMP alternator but it's not even connected, there is no engine in the car even, I'm just testing lights. I had a 10 gauge red wire that came out of the light harness connector which had been spliced with a black wire halfway between and was suppose to be plugged into the B terminal of the relay but on the wiring diagram it said to remove it with 60AMP. I removed that wire and just had the red starter wire hooked to the B terminal and that's when the relay fried and melted the battery cable. Before this happened we were getting the constant spark so I took out a couple fuses and tried to reconnect and was still getting the strong spark when connecting the negative cable. None of the fuses have ever blown throughout this continuing to connect the cables. All throughout this attempting to test the lights everytime I hooked up the negative last it would spark at the battery and at the B stud of the realy. So something is going on at that circuit right? What could be going on?
