JeffisOld
Old, Ugly and generally Disagreeable!
The area in the image below is the lip above the firewall,
The image below is the trunkwall inside,
When I have removed all the visible red corrosion there are little black lines continuing into the steel that is obviously corrosion. How to I actually STOP the corrosion without cutting out all the steel?
The plan has been to use POR-15 on the areas like the inside of the trunk andvthen topcoat accordingly. There are areas like the lip above the firewall that I was planning to use SubLime Green Sherwin Williams body color. Undecided on 1k or 2K paint yet though. As you can see the trunk lip is another area that makes me sweat! The corners of the rear glass will be replaced with AMD patch panels I bought in PA at the show. I am hoping a newb like me can make this happen successfully. I have many times in my life been told I have more balls than brains, I just hope I have not overloaded my *** with my alligator mouth.
Please help!
At least offer me a painless method of suicide. Thanks
Please help!
