Plug Gap
70wayfarer
new zealand
what plug gap should I have with V2 Vortech. plug i'm using is a NGK BPR6ES with 35 thou gap. cheers
Nice Ute,bump.Looks like, a new MSD digital box,and a separate timing retard box.
I'd say you're probably in the ballpark if you're running 8-10lbs of boost. You could probably tighten them up to .028-.030 even. I wouldn't go any wider, though.
thanks guys....been busy at work damn it, hence the late reply.
when I had my foot up it doing the staging burnout it sounded like it was on the limiter, but had not reached the set limit. even my tuner didn't pick up on that.
have set the gap to 28 now and sounds cleaner and crisper even at idle. a mate with a screw blower suggested 34 35.
going to a track meet on weekend coming so will let you know the difference.
cheers once again. this forum is awesome.
