Plugs
MassDart
Lifelong Dart fan
Wales, MA
My Magnum 360 build is complete. Just wondering what everyone uses for plugs for these. I have a fairly mild Lunati cam, 2.02 intake heads etc. Stock spec plugs good?
On a reasonably mild build with a factory-style electronic ignition, I'd start with a factory plug (like an Autolite 3924) gapped at .035. Once you've got a base tune established, run it for several hundred miles then pull the plugs and read them. Adjust the gap and heat range as necessary.
