Ply Volare disc brakes
A68DART360
Hesperia, Ca
I am looking to change over brakes from SBP drum to LBP disc brakes. Does anybody know if disc brakes from a 79 Plymouth Volare wagon will work on a 67-72 Dodge dart if I get spindle, caliper & bracket, and upper a-arm assuming I would need the upper arm for the larger ball joint. thanks in advance. Eddie
yes they work fine, you are correct though that you need the upper A arm with lbj.
(some people mention the height difference but it's small enough you can still align the car just fine.)
They work fine.
You need upper A arms off a 73-76 A body with large ball joints. The volare arms will not work, leave them behind.
what is the difference with the a-arms. it is a 4.5 bolt pattern right then shouldn't it be the larger ball joint a-arm also.
got it. wasn't sure if the a-arm would work or not and didn't want to pay for it if I wasn't able to use it. Thanks again for the info.
