Moparmarty50
Active Member
I played this radio today (9/20/20) for 30 minutes without an issue. On / off / volume switch, bass / treble, manual tuner knob, push buttons work as they should. I set each of the presets to local stations. There is a little wobble in the tuner knob but doesn’t affect tuning. Forgot to check if the dial light works. No cut or boogered up wires. Face plate and rear mounting bracket is included. Item in Grove City, Ohio 43123. $60 + the ride. Pick up available. Respond with your zip for USPS shipping cost.
