Pneumatic/ Vacuum Lines Under the dash on the Heater and A.C. Early A
Heating / Cooling / AC
  1. sgrip65
    sgrip65 66 Dart GT 273, 65 Dart GT 273 HiPo FABO Gold Member
    262
    116
    Oct 27, 2018
    Ia
    Local Time:
    9:34 AM
    I am still in the process of building my 65 Dart. When I took the A.C. and Heat boxes out from under my dash, I marked the rubber lines/hoses with tape and paint. Unfortunately, in the past two years, the tape came off, and the paint marks have disappeared. The red/yellow striped hoses hook to either side of the vacuum actuators and, again, are black with yellow and red stripes. They, then, venture to the vacuum control switch within the dash controls. I looked in the FS Manual, but everything is in black and white diagrams with no indications of which side is red, and which side is yellow on the striping of the hose to the vacuum actuator part which moves the door opening and closing rods. As well, the switch on the dash is a problem for me. Can anyone help me with the routing of these hoses? Your help would save me a bunch of time. I would, would, very much appreciate your help. Thanks. sgrip65
  2. sgrip65
    262
    116
    Oct 27, 2018
    Ia
    Local Time:
    9:34 AM
    I found some information on line, and that info stated that the RED striped hose goes to the ROD side of the actuator. I am correct in that information? Any help on this would be appreciated. Thanks. sgrip65
