[SOLD] POL Tubular Control Arms with ball joints.
MidnightSwinger
Woodland CA
USA made tubular upper control arms(big ball joint) from Performance Online. Includes upper and lower ball joints. See link for specs. Everything is still sealed in its original packaging except one control arm which was removed to to check it out.
1960-74 MOPAR-Dodge-Plymouth A-Body Tubular Upper Control Arm Kit with Ball Joints
$350 shipped from Woodland CA 95695
Will the ball joints fit the stock spindles (drum brake) ? meaning can i replace my extisting upper control arm and lower ball joint with this or does it require different spindles? I want to keep the drum brakes. I have the small bolt pattern wheels I'd like to keep.
Im not 100% sure but don’t think so. I think it’s for BBP cars
