straightlinespeed
Sometimes I pretend to be normal
I have these polished aluminum slots that came off of my car. Previous owner swapped the front to discs and they had the LBP. He still had the SBP rear axles. So with that being said 2 of them are SBP, 2 of them LBP. They all measure the same. 15" x 7" with 3-7/8" backspacing. One of the center caps is broke and will not stay on the rim. They could also use some cleaning up.
I will separate the rims if you only need one set or another. Asking $200 for all 4 or $100 for a pair.
