drtybttr
Time to sell my edelbrock d4b intake. I believe this is the is the one for the older 273 heads with the different bolt angle and small bolts, with the smaller style 273/318 ports. First of all it doesn't appear that the ports have ever been touched or modified at all. I don't see any cracks in it or any welds. The thermostat holes are good. The four outside carb bolt holes have been helicoiled and they all hold the bolts that come with them just fine. If you need to use the inside holes, they will need a coil. If your running a holley, edelbrock or carter afb carb it won't be an issue because you can just use the outside holes. Obviously the intake is dirty and needs a little clean up, but these are getting harder and harder to find. And the blue is just some paint over spray. I have taken a bunch of pictures to try and show all angles so there aren't any surprises. If you would like more pictures of anything specific let me know. $175 and the ride.
