Remember these that have been out of stock for...........EVER
Magnum Poly-Locs
Looks like PST had picked them up.
PolyLoc Motor Mounts
Magnum Poly-Locs
wHY IS THAT ? Somthing besides the price being high ? I have the shumacher poly mounts and they have lasted 6 years now , the old stock mounts used to rip apart every 3 months on my car . for that price I would probably go solids. I bought mine cheap from a shop that nevr used themThey can keep them bad boys, too.
Interesting... How much power have you seen these hold up to.............
Hell, I'll drill my mounts and run a bolt through them before 200 bucks comes outta my wallet for motor mounts.
I just picked up a pair of new Polylocs. For much less than retail. I'm replacing the Morroso solid mounts I just installed in my Dart. Man I forgot how much vibration they transmit thru the whole car. I didn't mind when I was younger but not on my street cruiser.
had my motor out last winter to fix a seal and add a Torque converter. still looked brand new. is yours a stick shift?
Oh I won't forget. It might be a little while before I get to it but they're yours.Don’t forget...I have dibs on those solid mounts!!! Let me know when you want to be paid and I’ll get it done.
what brand poly locks , or are they all the same ? i've had my shumacher poly locks in fotr 8 years 7with the 340 with 425 tq and 2 with the 426 with 564 tq they still look new . guess I drive like a pussyPoly mounts are garbage, inherent in the design.
They slide apart.
The two metal sides within the poly that don't touch are vertical, so when the engine torques they slide apart.
Went through a few sets under warranty, built heat shields, chain on engine, etc. They're just designed wrong.
Check them if you got them, because you won't know unless you do.
I knew because my engine pokes through the hood.
Pic is driver's side, nowhere near headers or heat.
I’ve got some solid moroso mounts. Come to the mopar Nats Woodburn if it’s still going to happen.Don’t forget...I have dibs on those solid mounts!!! Let me know when you want to be paid and I’ll get it done.
