fonzy
Ok..I've decided on my plan of action on the floor pans, I'm going to spot weld them in and seal em up, I've got a weld through primer I'll use on the welding areas. My problem is the hat channels, I've got a soda blaster I used to get most of the surface rust off with, should I go ahead and use por 15 is inside of them where I can't get it really shiny clean?
