Portable [ inflatable ] hot tub questions
22dog22
northampton ,pa
Hi All, wife wanted a small portable hot tub for all of her pains. We are in Penna. 1st time owner of something like this, have been reading up but still have questions. This unit just plugs into a standard 110 outlet so heater is not that strong. 1st question do you need to keep the temp up high 90 degrees- 104 degrees ?, 2nd does the pump need to run all the time ? Have just set it up , filled with water started heater and pump on Monday night added chemicals today . The unit is a Coleman Tahiti inflatable hot tub rated to work down to 14 degrees.
