[WANTED] Posi-8.75 rearend for 1966 dart 5on4
rrrickkk
lakeland florida
Rating - 0%
0   0   0
I have the axles but am hoping for the posi-rearend. Maybe I'll get lucky and it will be nearby in Florida where I live. Even if you don't have one, do you know someone who does? I've had this car since 1969. My 7&1/4 is shot. Rear bearing in Transmission seized the drive shaft and twisted it in two. That broke my transmission casing, bell housing and damaged the rear end. Also put a couple of cuts in the floor pan as I was coming back from Md. Happened all in less that 2 seconds.
I could probably set you up with a housing and center section if you'd like. 489 case, 3.23 gear, sure grip. PM me if interested
You check with waggin he may have something for you and he isn't too far from you. also you should look for a limited slip rear, POSIs are for Chevy's. :)
