The rear wouldn't be too hard, since 4x4 Dodge trucks used that pattern with an 8.75" axle in the early 70s. You could shorten the shafts to fit an A Body axle. I might actually have a pair of those shafts stuffed in my shed somewhere. I'm not sure about backing plates and drums, but the trucks ones would probably work.
The front might be a bit more work.
What wheels are you talking about that are only available in that pattern? If you're thinking about wheels from a 2002+ Ram, be careful because those wheels are designed to work with a 9/16" stud, not the 1/2" studs that the earlier stuff used.
